Go to Post Thats what makes FIRST so unique how culture and the time is reflected through our bots, but at the same time we all get along...with no problem. - Dan Richardson [more]
Unread 16-05-2015, 03:03
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Offseason Gearbox
Can CAM do this for you or do you have to put in all the radii manually?
What size endmill would you normally use as a minimum for something like this?
You should just use the fillet tool in solidworks/inventor/whatever and add .010+ to the nominal radius when you create the fillets.
I dislike using anything less than 1/4" diameter in 1/4" plate. with 1/4" cutter diameter you can go full depth (with a reasonably rigid machine and good chip evacuation). 3/16" and smaller won't allow you to do that.
2001-2004: Team 100
2006-Present: Team 254
