Go to Post What else could you do with a t-shirt? Wait... never mind... I retract my previous statement and realized this is FIRST and we can do anything with anything. ;) - Jeremiah Johnson [more]
Unread 17-05-2015, 20:25
rponmalai's Avatar
rponmalai rponmalai is offline
UCI
AKA: Ravi Ponmalai
FRC #3476 (Code Orange)
rponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of light
Re: pic: Offseason Gearbox
Originally Posted by Joey Milia View Post
And once you do how will you get it to stay in the wall of the tubing?
http://imgur.com/a/n6cZ8
One of the things I was playing around with in this design was running the timing belts through the tubing of the drive base. I have an access hole for putting the belts through that can easily fit the bearing. The entire shaft would be held together with snap rings. The grooves for those snap rings are on either end of the output shaft.
