Go to Post It's super-ironic that a question about searching was found via searching. Whodathunk? - Brandon Martus [more]
Unread 17-05-2015, 20:36
Joey Milia's Avatar
FRC #0192 (GRT)
Re: pic: Offseason Gearbox
Originally Posted by rponmalai View Post
http://imgur.com/a/n6cZ8
One of the things I was playing around with in this design was running the timing belts through the tubing of the drive base. I have an access hole for putting the belts through that can easily fit the bearing. The entire shaft would be held together with snap rings. The grooves for those snap rings are on either end of the output shaft.
That answers the bearing questions. What's the belt set up you were thinking about? Pulley tooth count and belt size?
