Go to Post (I'm sure that Dave is holding his breath for "welding with Jello".) - jgannon [more]
Unread 17-05-2015, 21:04
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Re: pic: Short coaxial swerve module
Originally Posted by Joey Milia View Post
I won't dispute worm gears high reductions but i wouldn't describe them as relatively efficient. The highest efficiently you'll get is 86% with a four lead worm. At best this would be replacing the two stages before the co-axial, a miter stage and a timing belts stage, each around 95% or higher. I too am unsure of the benefits of a horizontal cim for a coaxial swerve but I don't think a worm gear would be beneficial on the Cim motor. However, using a worm gear for the steering motor is a different issue and has more merits in my opinion.
You are correct, sir. The miter gears I've had experience with are in all likelihood far below 95% efficiency, however upon further research I found that good quality miters in rigid and accurate housings can achieve those numbers. And of course belts are highly efficient, if properly tensioned.
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
