Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 20-05-2015, 15:19
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
pic: Simple Chain-in-Tube Concept
Unread 20-05-2015, 15:37
Re: pic: Simple Chain-in-Tube Concept
I really like the use of tubing to mount the ballshifter, very clever.
Unread 20-05-2015, 15:50
Robotics Engineer
Thanks. I basically got rid of the plate and standoffs that come with the 3rd stage kit and made the output shaft and gear part of the drive rail. The gearbox then bolts on. I had reservations about putting 3 bearings on the same shaft, but since it's bolt tolerances holding the 3rd one on, I'm fairly comfortable with it.
Here's a pic with one gearbox removed.
Unread 20-05-2015, 16:00
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Brilliant. This is the current weakness in our chain in tube design using the ball shifters. Consider this stolen :cough: I mean borrowed.
Unread 20-05-2015, 16:01
Robotics Engineer
Send me a PM if you'd like the CAD model.
EDIT: Link below.
Unread 20-05-2015, 16:28
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Very nice Ty!
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
You mention reducing the diameter of the outer wheels, have you considered increasing the diameter of the middle wheel?
I'm thinking that versawheels with blue nitrile might have a large enough OD to give a decent amount of rock with 4" Colson wheels on the outside.
Alternatively, you could use 4" wheels on the back and middle and a 3.5" wheel on the front. That gives you the same amount of rock as a 1/8" center drop.
Edit: You can also use a vex 16 tooth sprocket on the 3.5" wheel down from the 17 tooth sprocket on the 4" wheels to try to get the surface speeds of the wheels more closely matched. This should reduce wheel wear.
Unread 20-05-2015, 16:34
Robotics Engineer
There's definitely a lot you can do with the wheels, I'm just a huge fan of the durability of Colson wheels and we have a lathe handy right in our workshop.
I've had a few extra requests for the CAD model, so here it is.
Unread 20-05-2015, 17:00
Engineering Mentor
AKA: Steve Bennett
Thanks for the CAD, looks pretty darn simple and bulletproof.
As far as colsons, Vexpro has 4", 3.5", and 3" Colsons. If we build something like your design I think we will use 1/2" smaller dia front wheels, whether we use 4" or 3.5" wheels for the rest.
Unread 20-05-2015, 22:51
philso philso is offline
FRC #2587
How are you going to attach the two vertical pieces of tubing to the horizontal frame tube on each side? It looks like there is not a lot of surface area and any fasteners that protrude into the frame tube may interfere with the chain and/or sprocket.
Unread 20-05-2015, 22:52
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
What's the reason for the slots in the tube that mount the gearbox?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-05-2015, 01:07
Probably to not overconstrain things.
Unread 21-05-2015, 04:23
Aren Siekmeier's Avatar
on walkabout
You want the gearbox position to be driven by the third bearing in the plastic housing piloting onto the shaft captured in the tube. This sets the appropriate gear spacing and prevents misalignment of any the bearings or the shaft. Then the bolts just clamp everything in place wherever it ended up.
I also really like the boxtube standoffs. I'd played around with this same idea, but still using a version of Vex's third stage plate, requiring more pieces and more disassembly to get the gearbox away from the final gear. The boxtube cleans this up a lot.
Unread 21-05-2015, 06:56
TD78 TD78 is online now
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Really nice job Ty....thank you for posting your model. I think this design concept will start to become more popular in the near future.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 21-05-2015, 09:24
Robotics Engineer
We have a TIG welder in our shop, so they'll be welded in place. If you don't have access to a welder, basically any motorcycle shop near you will have one and you could work with them for a sponsorship.
Mostly to not over constrain things as stated above. Secondarily to make it so that I don't have to keep track of left and right versions of the tubes since putting a hole in the middle of the tube would cause the tube to interfere with the gear on the rail.
