Go to Post This problem will be solved by one of the largest problem-solving machines in the world...the FIRST community. - ZZII 527 [more]
Unread 23-05-2015, 22:44
EricH EricH is offline
Re: pic: Wood Coast Drive
Originally Posted by mman1506 View Post
As I said earlier you are mixing up polycarbonate and acrylic. Acrylic is difficult to drill, polycarbonate is very easy to drill.
Ah. (Makes me wonder why acrylic is found with FRC teams--and their "unskilled" drillers--around, but that's beside the point.)
Now, for the impact resistance: polycarb vs birch. Polycarb deflects, birch absorbs. They're about the same, but I'm going to have to give that to the plywood on strength-to-weight ratio. The main issue with birch ply is that it absorbs by getting dented or, eventually, splintering. (Acrylic never even enters this discussion, as the "standard" test for identifying unknown clear plastic is to clamp firmly and hit with the biggest hammer in the area--if it doesn't break, use the polycarb, otherwise it was acrylic.)
