Go to Post amazing stuff. - Specialagentjim [more]
Unread 24-05-2015, 13:36
TheOtherGuy's Avatar
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
Re: pic: Wood Coast Drive
For reference, baltic birch plywood is ~0.65 g/cm^3, while polycarbonate is around 1.2g/cm^3 and aluminum is ~2.7.
There are many more factors that determine what material we use than simply density and strength. As Cal mentioned, we use plywood because it is incredibly cheap and easy for our team to work with. If using polycarbonate makes sense for your team and application, go for it.
The cutter also leaves a fairly smooth finish on the sides (structurally, though, the lightening patterns aren't really justified).
