Go to Post there should be a continuous cascade of knowledge spilling over to the less experienced team members and and continuous upward flow of members gaining experience. - ebarker [more]
Unread 26-05-2015, 00:20
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Re: pic: Help with solid works gears
Originally Posted by orangemoore View Post
I suggest you design the plates using circles as place holders for gears instead of creating an assembly. This will make your life a lot easier.
This video should show how this works.
https://youtu.be/GCjBx3TXB6Y?t=19m32s
On top of the plate design using circles, I would advise using sketches to making your entire 2-D conceptual design before moving forward. It can keep things organized really well if you dimension and use relations properly.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 26-05-2015, 08:14
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
A really useful page I use quite a bit: http://computers.martinchick.com/spur_gear.html
You'd want to calculate the (Pitch Diameter)/2 for both gears, add them, and that'll be your distance between centers. I usually add about 2-5 thou (0.002"-0.005") to the sum, just for tolerances in manufacturing.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 26-05-2015, 10:21
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Here is a solidworks file used to design a 3 CIM gearbox:
https://drive.google.com/file/d/0ByD...ew?usp=sharing
It has a 50 tooth gear in the center, with three cims with pinions driving it. On each cim we have included 3 different sized pitch diameters (12, 14, 17) so that the pinions can be swapped to get different ratios. Each pitch diameter circle is driven by an equation: pitch diameter = number of teeth/ 20 +0.002 because these are 20 dp gears. I have also added 0.002" to all pitch diameters to get the 0.002" extra on all center to center distances. Also included in the first sketch are mounting hole locations for the cims with each of the different pinions. Around each pitch diameter I have a circle 0.1" larger in diameter to show where the tips of the gear teeth are to make sure nothing will collide with them. Also shown are the bolt heads of cim mounting screws to make sure everything will clear.
The 0.002" extra value is not a strict rule. We have found that it works well for enclosed gearboxes that are waterjet.
I wish solidworks had sketch annotations so I could label every circle. It can get ridiculous trying to remember what each of the dozens and dozens of circles represent when doing a more complex gearbox.
Here is a screenshot of the assembled gearbox:
The cim mounting hole locations in the plate that the cims mount to is driven by the sketch in the front plate, so that any change made to the front plate will propagate through the whole assembly.
These gearboxes are a good example of how you can use solidworks bottom-up (start with sketches) or top-down (start with assemblies and use the parts to drive sketches for other parts). For example the gearboxes start with sketches, but the robot bellypan uses components placed in the assembly to drive the position of mounting holes.
