Go to Post Coming soon to an Earth near you; an Australian team (or 2). Stay tuned. - Elgin Clock [more]
Unread 26-05-2015, 09:59
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: Guess The Next Game :)
Originally Posted by MoistRobot View Post
Skee ball with bowling balls.
I would rather KEEP the structural integrity of my skull, thank you.
Unread 26-05-2015, 16:02
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
I'm sure adequate saftey constraints could be put in place- rolling only, no upward trajectories, no launch from more than the height of the ball, penalties for overshooting the target, etc.
You could make the balls different weights but otherwise the same and add a balancing coopertiton end game. Would be fun.
Unread 26-05-2015, 22:24
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
I think the game will include robots on field doing something. I am thinking about the game now and will give you more information on January 9th.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 26-05-2015, 22:58
EricH EricH is offline
I predict that telerobots, controlled by the type of vertebrate known as "human", will move and displace objects to score points.
I also predict, without having seen the game at all, or having any other knowledge of said game, that IRI will modify the rules to remove the single most hated one, or set of them.
Unread 27-05-2015, 07:27
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Next year the field will be a suspended grid of pipework and the robots will have to navigate 2' off the floor around that grid like monkeys in trees.
The field pieces will be foam bananas.
Unread 29-05-2015, 08:36
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
... telerobots, controlled by the type of vertebrate known as "human", will move and displace objects to score points. ...
^+1
Originally Posted by techhelpbb View Post
... a suspended grid of pipework and the robots will have to navigate 2' off the floor around that grid like monkeys in trees.
Monkey-bots!
Home zone carpeted areas at either end of monkey bar grid will be the only floor surface that robots can legally contact. Floor below the monkey bars will be covered with blue carpet and designated "the water" <insert water game comment here>. Monkey-bots that contact the water will be penalized. Scoring will require a successful, aerial traverse of the bars to retrieve bananas.
Bananas will, of course, be pool noodles.
Richard Wallace
since 2003
Unread 27-05-2015, 08:11
Gee, I hope you're right.
Unread 27-05-2015, 16:55
BariSaxGuy's Avatar
BariSaxGuy BariSaxGuy is offline
FRC #5013 (Trobots)
BariSaxGuy is an unknown quantity at this point
Ground contact isn't allowed. You'll have to make a helicopter. The game will be called Helicopter Hazard. You have to pick up pool noodles and drop them in goals.
Unread 27-05-2015, 17:34
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
I'll xpost what I made in the rumor mill subforum.
I think it could be field hockey, rather than the typical puck-based hockey. With some durable foam-ish (whatever material, just not something that will be shredded in four seconds) balls, they could put goals at different heights for varying points, much like years past. Ground goal 1pt, mid goal 3pts, maybe a high goal (with a net over that area for safety or whatever) for more points.
I think hockey would really allow for more diversity in strategy and builds. Defensive bots can try to be a powerhouse, with a 6 CIM west coast drive and just push people out of the range of the goal. There could very well be goalies, if the goals are wide enough. Offensive bots could either try to be powerhouses and move defense out of the way (us in 2013...) or agile and try to move around the defense, with something like a lightweight mecanum drive.
Some rules would be you can't have the ball touching your robot more than X inches off the ground for N seconds or more, shooting from beyond half-court is extra points, human players can inbound C amount of balls at a time, robots can only possess or control Z number of balls or less at a time, etc.
I think the strategy involved in beating an alliance would be a VAST improvement over 'strategy' in 2015.
I strongly believe this will happen in the next few years. If it does, i'll only be sad I won't get to be with a team for it.
Unread 27-05-2015, 17:43
Green Potato Green Potato is offline
AKA: Tory Farmer
FRC #0422 (Mech Tech Dragons)
Team Role: Tactician
Green Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of light
Normally I don't play guess-the-next-challenge, but I'll give it a shot.
-Every year, FIRST seemingly alternates a ball game with a non-ball game. Because last year was NOT balls, this game will involve balls.
-Given that balls will be in the game, it is necessary to approximate the size of these balls. We've already had big balls (har har) recently in Aerial Assist, so I predict the balls will be a smaller size next year, almost like rebound rumble's size.
-It will likely be a game where alliances COMPETE ant interact, saying that the community as a whole seems to want something different than last year's average score ranking system.
-I'm thinking a sports-related game. FIRST hasn't had one in 2 years (although A.A was supposed to be volleyball), so I see one coming our way soon.
Thus, from these conclusions, I'm looking at...
-Baseball
-Dodge ball
-Football
-Golf
-Soccer (maybe, but we've sort of had this one before)
-Tennis
Of all these sports, and I'm sure I'm missing a LOT, I'd pick almost a dodgeball-like game where the goal is to have as few balls on your side of the field as possible, and maybe a secondary objective of throwing balls through something to get additional points.
Everything that can go wrong WILL go wrong, except the things we expect to go wrong and actually plan for.
Unread 28-05-2015, 15:30
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I don't see that so much to be dodgeball as "hot potatoes". If each side had a large funnel goal that feeds a long, low slope helix or other delay mechanism that kept the "receiving" alliance from quickly rebounding scored balls, that would provide your secondary objective.
Unread 28-05-2015, 20:58
Jacob Abel Jacob Abel is offline
FRC #1557 (12 Volt Bolt)
Jacob Abel is an unknown quantity at this point
-Baseball
-Dodge ball
-Football
-Golf
-Tennis
Water Polo?
