Re: pic: Gearbox in 2' by 1' tube. WCD
I would suggest slotting the top of the tube where the gears are. This would make maintenance easier. If you want the gears to be covered, just put a piece of polycarbonate/wood/sheet metal on a hinge of some sort.
Would the front and rear set of wheels on each side be linked together or would they turn independently?
Would the overall volume be very different if the motor is relocated so that the motor pinion meshed directly with the large gear? This would eliminate two stages of gearing. |
It is not seen well, but half of the shaft on the gear next to the cim pinion gear is covered by the cim. So the gear would have to be very large to make space for the sprocket and I don't think the sprocket would fit. |
If you will have four of these gearboxes, you might not save any weight. In a "normal" WCD, you have one gearbox on each side. With the scheme show, there will be two extra large gears plus the other small gears.
If you do not link the two gearboxes on each side, you will get the power of only one of the two CIM motors on each side for much of the time since only two wheels on each side will contact the carpet at any one time. |
