Go to Post As we were lying the robot down to work on it "CAD me like one of your french robots" - 1uan [more]
Unread 17-06-2015, 12:11
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a jewel in the roughchrisfl is a jewel in the roughchrisfl is a jewel in the roughchrisfl is a jewel in the rough
Re: pic: Concept Swerve design
That's if we go with a tank drive. I just thought it would be something cool to have if we want. Also whenever I drive mecanum, I just used the wheels to drift into tight places or get out of pins
Unread 17-06-2015, 15:29
Looks pretty good. I'm wondering about that thrust bearing at the top. Is it only going throug one plate, or is there another one that we can't see? With the wide shoulder your bearing has it might be okay, but keep an eye on it, and maybe add mounting holes for an upper plate just in case something goes wrong.
As other have said, your lightening pattern is too aggressive.
I would also add another bolt to mount it on the siderail, as the lower-right bolt is only secure by the bottom of the 2x1 there, which is only secured by a gusset plate or bellypan, so it will move around.
Unread 18-06-2015, 16:06
FRC #1991 (Dragons)
The module is only going through one plate that is 3/16 in thick
