Go to Post A drag racer can have all the output torque in the world, but it does no good on ice. - Paul Copioli [more]
Unread 06-26-2015, 01:41 AM
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Re: pic: FTC Custom Drive Train
Originally Posted by ehochstein View Post
How do you plan on attaching the motors to the gearboxes? I would assume the 6 mounting holes on the face, loctited?
There are holes in the gearbox plate that line up with two of the 6 mounting holes on the motor, and yes, I would probably use a little loctite, but not too much in case I need to remove a motor later.
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
Unread 06-27-2015, 03:51 PM
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I would suggest using more than two of those holes, we found that using a minimum of 3 worked best.
The gears you are using don't appear to be tetrix gears, what are you plans on mounting them to the output shaft? We've been looking for alternatives to the tetrix gears and would be interested if you found a solution! Currently, we are looking at manufacturing our own solution.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 06-27-2015, 05:14 PM
Good to know about the mounting holes. Thanks! I'm using BaneBots 1/2" hex hubs for 6mm bore to mount the VexPro gears into the motors.
Here's a link:
http://banebots.com/c/WHB-HM-HS4-M6
Unread 10-05-2015, 08:24 PM
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Here's a link:
Do you by chance have a close up view of just the gearbox with the Banebots adapter or be willing to share your CAD file. were needing to use a 1/2" sprocket for our drive train this year and having a hard time understanding how I might be able to make one of these adapters work.
Unread 10-05-2015, 08:31 PM
Knufire Knufire is online now
What size sprocket? AndyMark recently released this: http://www.andymark.com/product-p/am-3185.htm
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 10-05-2015, 09:33 PM
I couldn't find the CAD file for them while I was designing this, and I was kinda lazy so I didn't bother making my own. So there isn't actually an adapter in the CAD, but it's designed to use them.
It's a pretty simple set-up, though. The adapter should tighten right onto the 6mm shaft. You can then slide your sprocket onto there. The adapter has a lip on one end so your sprocket doesn't slide off that way, and it has a groove to add the retaining ring for the other side. You could probably put some spacers in there to get the sprocket into the right position. You could also cut it to length and machine your own retaining ring groove if you have access to a lathe.
If you send me a picture or a better description of what you're trying to do, I can probably be of more assistance.
Unread 10-05-2015, 11:27 PM
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Here's a CAD file of the 6mm to 1/2" hex banebots adapters that I whipped up. Both in Creo and STEP flavors. Feel free to use however you want-- this is as close to the technical drawings as I think I can get.
This one is three wide, but I can make a 1 or 2 wide if you'd like. It's a real shame that it looks like BaneBots is going to stop selling these.
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 10-06-2015, 03:33 AM
My brother managed to make one out of a piece of VEXPro Thunder Hex by drilling out the bore to 6mm on the drill press and drilling a hole in the side through which he tapped the threads for a set screw. It was pretty cool.
Unread 10-06-2015, 08:52 AM
AKA: Chad
I thought about doing the same thing with the thunderhex. we did this last year with our FRC team to adapt a 10 turn pot to a shaft to track the height of our linear lift. worked out really great only instead of drilling and tapping a hole in it we cut a slit down it and used a shaft collar to lock it back together. we may have to see if we have a piece of thunderhex around and try this out.
thanks for the cad file. and the explanation of it. do you see any reason this wouldn't work with the #35 sprockets from vex pro?
-Chad
Unread 10-06-2015, 09:53 AM
-Chad
#35 chain on a FTC robot?
Unread 10-07-2015, 12:13 AM
AKA: Nick Aarestad
-Chad
I don't see a reason why it wouldn't work, but I'd probably go with a couple of the #25 sprockets instead of one of the #35 doubles. I'm pretty sure buying an adapter plus two of the VexPro sprockets is cheaper than getting a single sprockets from AM or Tetrix (although I suppose those have the advantage of just dropping in).
tumblr | twitter
VEXU UMN (2015-??)
Unread 10-07-2015, 10:22 AM
The biggest advantage of the AM sprocket is not having to rely on a set screw to transmit torque from the motor output shaft. AM found the slit + collar clamp method that IceStorm mentioned to be more reliable, which is what that sprocket operates on.
