Go to Post So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 07-07-2015, 15:49
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: Servo Power Worksheet
Originally Posted by JamesTerm View Post
I don't know what "No Load Speed" means... I have not looked at previous years game manuals yet, but wonder if this issue was ever addressed.
No Load speed for a servo is the same as "free speed" for a motor - the speed that it moves when there is no load (other than the internal friction and inertia of the motor and gearing). Another way of viewing this is as zero output torque (all of the torque of the motor has been used up in friction). As was noted earlier, if you assume that the torque and speed scale in an inverse linear fashion (usually a decent approximation), the peak mechanical power output is at one-half of the no load speed, and one-half of the stall torque, which is one-quarter of the max power rating.
Last edited by GeeTwo : 07-07-2015 at 15:50. Reason: removed and fixed "proportional"
Unread 07-07-2015, 16:17
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Ah... no load as in... "NO" load... rather than no as in No. (an abbreviation for number). Got it... thanks.
