Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 12-07-2015, 23:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Four Speed Three CIM Gearbox
To me, the big "why" is why have four speeds over about a total 3:1 high-to-low ratio? If you're going to bother with four speeds, spread them out a bit wider!
At a minimum, I would put the shifts a factor of 2:1 apart, resulting in an 8:1 overall ratio from high to low. At a "standard" 2.56:1 ratio between shifts, the total range would be 16.77:1. At 3:1 per shift, it would be a massive 27:1, which could be a real game changer in some highly defensive games or games with steep ramps. Especially if you want to reserve some CIMs for manipulators!
Last edited by GeeTwo : 12-07-2015 at 23:17. Reason: Added 2.56 sentence, Especially sort-of-sentence.
