pic: 6in Butterfly Module With Piston
Looks pretty solid!
Re: pic: 6in Butterfly Module With Piston
might be nit picking here, but isn't a butterfly drive omni wheels as opposed to mecanum wheels?
If you put omnis on it then you're not going to get much utility out of it. Really, what do you gain from switching between traction and omni? You turn a bit better. That's about it.
However, if you have mecanum wheels, you can switch between having insane push power, to having a fast and holonomic drive. You get more utility out of it this way. |
Until you add a strafe module in the middle.
I'm not going to claim to be an expert on butterfly drive, but I wouldn't feel comfortable cantilevering that module out like it's a WCD, I'd rather support from both sides here. But then again I'm from the east coast...
Back on topic and not debating the pros/cons of butterfly vs. mecanum, I have to agree with pmangels somewhat that cantilevering the module sounds quite risky.
I think this would have to be paired with some bulletproof bumpers or an outside rail in order to work super well. That being said, I love what you're trying to do, and I really wanna see it work. Last edited by Kevin Leonard : 21-07-2015 at 12:50. |
#10
How are you going to manufacture the bracket for the cylinder? it looks dove tail joint I would use for wood drawers.
#11
See the Battlebot Bite Force's construction here |
#12
That piston mount plate might bend over time, particularly if there are bumpers contacting it (shoving can get them). We had a similar issue with bumpers in 2014, but it depends on where your bumpers are vertically.
#13
<Grumpy Old Man Rant>
It's a cylinder, not a piston! <end Rant> |
#14
same. However, to be fair to all "piston" people, if the piston wasn't there, the cylinder wouldn't work.
#15
Some items to ponder on this design, but it looks like you are making progress!
![]() Pic 1: -The black arrows show close proximity of the standoff bolts, the stiffness gain is minimal, you may consider spreading them around to increase the stiffness or eliminating a bolt from the pairs. -The blue arrow shows the force applied through the module into the cylinder, and the red arrows are the resulting vectors. This places a moment indicated by the second red arrow and creates a high stress area. Whether the .25" plate will yield or not would have to be determined for the application, but the long mounting point increases deflection and reduces stiffness. This would be unwanted for turning in a tank drive with traction wheels as less stiffness will increase bounce during turning. Stiffness is required to allow the wheels to break traction to scrub smoothly. There are many ways to increase stiffness, Skywalker gave one good solution: Quote:
-.25" material is plenty thick to tap, the nuts circled may be eliminated by tapping into the back plate. Pic 3: -The blue arrow shows the restriction the .25" plates on the top on bottom rails provide, however, there is no loading in that direction. The bolts also restrain the part for rotational loads. It appears this is an attempt to use the pre drilled holes for assembly, if so, the plates could be removed afterwards to reduce weight and be used as an assembly fixture only. -The green circles are suggestions for rivet locations. They are lower weight than bolts and easily hand assembled. The rivet holes in the .25" can be laser cut like you want, the plate clamped into position, then the frame rail drilled, and then riveted. -The red arrow is a suggestion to move the pulley to the outside of the wheels to reduce the bending moment on the axles. Quote:
Do you guys have more information to support these feelings? |
