Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 22-07-2015, 17:54
hectorcastillo's Avatar
hectorcastillo hectorcastillo is online now
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
pic: My First Sheet Metal FRC Drivetrain
Unread 22-07-2015, 17:57
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: pic: My First Sheet Metal FRC Drivetrain
As you mentioned, the double-cutout is going to result in a lot of twisting between your two drive pods.
A couple of things you can (and should) do to mitigate this, without any extra systems. First, there's no reason for your cross members to be so close together. You'll get much more rigidity if you move them to the extremes of the bellypan.
Second, your cross members are only supported on a single flange. They will have a tendency to bend about this flange. You can add a whole lot of strength by modifying the cross member's flange so that it rivets to the top flange of the drive rail.
Unread 22-07-2015, 18:06
The empty spaces on the belly pan are going to be occupies by other mechanisms, but as soon as they get put in, I'll move the supports as far out as I can without interfering with whatever's there. Also thanks for the suggestion to rivet to the top flange of the drive rail
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
Unread 22-07-2015, 18:33
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
If you want a more accurate mass than just a guess, which at some point you probably will, you can get that data from CAD. When I model things, I just set the materials for the different parts I'm making, and it spits out the mass for the part. For things like CIM motors, cylinders, and bearings, where there are hollows inside that I usually don't draw in, you can use the masses listed in the specs and override the mass property in the part drawing. Then, you should be able to update the mass property in the main assembly and get a fairly accurate estimate.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 22-07-2015, 19:14
asid61 asid61 is online now
35-40lbs sounds a tad low, especially with bumpers. and a lack of lightening holes in the sheet metal. 40-45 without bumpers would be my guess.
As Paul said, you can get accurate weight estimates by adding materials to parts and using the listed weights online for COTS parts. This is a major feature of CAD that can be used to excellent effect.
As Joe said, you will experience strength issues with those center members. Your superstructure should be designed to support your chassis if you're planning on keeping those cutouts.
Unread 22-07-2015, 20:00
I forgot to clarify; my guess for the drivetrain was without the bumpers. I got ~30 when I checked the mass properties, but the parts all had default material so I added a little bit to that. I'll do a more accurate weight measurement later after I'm done assigning weight and materials to parts.
Unread 22-07-2015, 23:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
A lot of really wild speculation took place about another three-CIM-per-side four-speed drive train recently on this thread. Four-speed seems less than fully useful for FRC, though I believe we did come up with a few edge cases that might call for it. PTO (Power-take-off) options seem more likely uses of second shifters on the drive train.
Unread 23-07-2015, 00:08
Abhishek R Abhishek R is online now
FRC #0624
Both threads were started by the same person.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 23-07-2015, 08:41
Professional Stat Padder
Assuming you add some superstructure connecting the two sides, I don't believe twisting would be a problem. As Chris said in the other thread, those gearbox plates look slightly too lightened, but if you put a few long standoffs between the gearboxes to cross-brace them, it might help.
Just make sure you understand why you made each design decision you did, and it looks great.
(2015-Present)
