Go to Post Something is subtly different about the competition environment that makes everything worse. - kaszeta [more]
  #31   Spotlight this post!
Unread 23-07-2015, 00:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Four Speed Three CIM Gearbox
I'm still wondering what was up with that central gearbox that was later distributed. It appeared to be an essentially 1:1 gearbox which brought four CIMs together onto a single shaft, which was then redistributed around on four separate swerve shafts. It seems to me that it would have been easier and more efficient to put a CIM on each swerve shaft, but to include a sprocket which tied the four shafts to the same speed to allow redistribution of energy as needed (e.g. as loading increased on two wheels due to acceleration away from them).
