Go to Post Each poster can bring respect to the topic, whether agreeing with it or not. - JaneYoung [more]
Unread 28-07-2015, 23:16
Aren_Hill's Avatar
Build Nifty Things
Re: pic: FRC3928 2013 Butterfly Module
Originally Posted by Dylan179 View Post
what kind of hub did you use for the traction wheel?
In this instance the traction wheel was made from a solid piece of 2.5" diameter Delrin, the Pulley was milled into the side, and two 3/8" bearings were pressed into it.
Had access to a CNC mill, decided to minimize the part count and not require ordering a pulley.
-Aren
A guy who likes robots.
Unread 29-07-2015, 16:14
DampRobot's Avatar
Physics Major
AKA: Roger Romani
And now I know where Adam got his 2013 offseason drivetrain design.
-Plutarch
Unread 01-08-2015, 20:54
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
What would someone look for if they were trying to find an extrusion like you guys used for the main structure of these rails? As well, how are you planning to connect the frame up once both side rails are completed? The pattern of those holes looks like it would be great for designing attachment points.
Unread 03-08-2015, 21:50
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
As this was our 2013 robot, you can see how the frame was designed to be assembled here.
Unread 03-08-2015, 21:58
Aren_Hill's Avatar
Build Nifty Things
Also for reference this is 3"x3" x .125" wall Aluminum tubing, nothing special.
Online metals has it but a local supplier will give a better price.
-Aren
