Go to Post I can tell you for a fact that students don't need smartphones in order to unproductively entertain themselves in a robotics lab. - remulasce [more]
Unread 05-08-2015, 15:30
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
Re: pic: WCD Butterfly Module
That's a really cool design. What is the weight of the chasses? Also when you have the high friction wheels down are the Omni wheels touching the ground?
Unread 05-08-2015, 15:40
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I don't have weight numbers at this point. The chassis itself is one we developed last summer and used this past season. So the only added weight would be the modules themselves.
In this configuration the omni wheels are allowed to ride along on the ground. Adding a spring to pull them up, if this was undesirable, would be a very easy addition.
Unread 05-08-2015, 15:44
Since they're geared 1:1 I doubt it'd matter too much if they rode on the ground. They'd have next to no normal force anyway.
Unread 05-08-2015, 15:45
Flywheel Police
Agreed, which is why the option was not added currently. My only worry is carrying the robot, they might have a tendency to want to swing down. The pneumatic tubing might keep this from happening though.
Very cool design. The use of the front rail as a brace for the piston is a bold idea.
I noticed that the drive chain will have to run from the center gearbox all the way to the corner so that it isn't on the pivoting sprocket (with a changing C-C distance). But if it does that, then the chain goes through the pivoting sprocket. You might want to make the pivot point the sprocket that's closer to the chassis to avoid this issue.
Unread 05-08-2015, 15:47
Flywheel Police
This is actually a chain in tube chassis, the chain run is identical to our chassis without the modules on it.
Unread 18-11-2015, 11:53
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
I really like this approach on how to make a WCD Butterfly drive!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
