Re: pic: WCD Butterfly Module
In this configuration the omni wheels are allowed to ride along on the ground. Adding a spring to pull them up, if this was undesirable, would be a very easy addition. |
Agreed, which is why the option was not added currently. My only worry is carrying the robot, they might have a tendency to want to swing down. The pneumatic tubing might keep this from happening though.
Very cool design. The use of the front rail as a brace for the piston is a bold idea.
I noticed that the drive chain will have to run from the center gearbox all the way to the corner so that it isn't on the pivoting sprocket (with a changing C-C distance). But if it does that, then the chain goes through the pivoting sprocket. You might want to make the pivot point the sprocket that's closer to the chassis to avoid this issue. |
I really like this approach on how to make a WCD Butterfly drive!
