Go to Post Frank is frank, and I like that. - rsisk [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 09-08-2015, 17:40
pic: GBX-127, bevel-beside-wheel swerve drive
Unread 09-08-2015, 17:41
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Re: pic: GBX-127, bevel-beside-wheel swerve drive
Can you better explain how the encoder is mounted? It looks like there's some kind of polycarbonate bracket going to the CIM, but it's hard to tell what it's doing or where it's mounting.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 09-08-2015, 18:06
cxcad cxcad is offline
FRC #1683 (Techno Titans)
I think he's going for something like a surgical tubing mount. That is the encoder shaft is connected to the shaft by a piece of surgical tubing. This method allows for some axle misalignment and is useful for low precision parts like the poly mount
Unread 09-08-2015, 18:09
Yup, that's it.
Unread 10-08-2015, 08:41
Professional Stat Padder
Why is it geared so fast? 17 fps for a swerve seems like it would be way faster than you'd want in most games.
(2015-Present)
Unread 10-08-2015, 09:44
I ran it through a drivetrain calculator, and I found that 17.6fpsish is the best time-to-distance for 2ft, which is perfect for getting around opponents. 17.7 is a little fast, especially given inconsistencies which the model doesn't catch, but it's easy to change the design depending on the game.
That's free speed, not adjusted; it should be between 14-15 adjusted.
Unread 10-08-2015, 11:34
Is this designed to be made with resources available to your team?
If so, does it use so many resources that it takes away from other systems?
Unread 10-08-2015, 14:24
Yes, the method of waterjetting + milling is one that was specifically tailored to our needs; materjetting is cheap, and using the DRO on the Bridgeport makes the tolerances for bores and holes spacings above what you can get with a waterjet. GBX-130 requires even less machining due to the use of a Banebots gearbox in place of a custom turning gearbox, and would be used if the ETA on our manipulator prototypes was very short.
Of course it takes away resources from other systems; a WCD would take a little less work than this particular model. A KOP chassis takes less work too. Hovever, due to various things within our team using a swerve drive is advantageous, even irrelevant of the game.
Unread 10-08-2015, 16:12
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Yup, that's it.
I meant what is the encoder itself mounted to, not how is it connected to the shaft.
Unread 10-08-2015, 17:20
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Is your Ma3 1:1 in relation to the steering portion of the module? It looks that its part of the first stage of the rs gearing.
Edit:
1. If your pressing the bevel gear into the wheel, why not put bearings into the wheel and make the assembly dead vs live? It would make the bottom of your module way more rigid. Also much easier to do wheel swaps, we were able to do wheel swaps in under 10 seconds on our modules this year.
2. I would recommend milling the side of your forks and adding a bearing to support the smaller bevel gear.
R.C.
MadTown Robotics Team 1323
Unread 10-08-2015, 17:43
Jared's Avatar
Jared Jared is offline
Looks pretty cool - if you're worried about the cantilevered bevel gear, I'd look at the AndyMark swerve module. They cantilever their bevel gear too, and I haven't heard of any issues with their setup.
Where do you plan on getting the bevel gears from?
Unread 10-08-2015, 22:04
A bent piece of polycarbonate.
Edit:
That's an error on my part. It should be an S4 incremental encoder, but I'm used to putting in an MA3 and forgot.
I tried 3/8" and 5/16" bearings on a dead axle, and basically I either had to use a 1/4"-20 axle, which is possible but not something I've had experience with, use a very weak bearing, or bore out the bevel gear hub more than I'm comfortable with. If a 1/4"-20 would work as an axle, then I would switch to that plus an 8mm OD spacer as a dead axle. 8mm because I would already be ordering 8mm/16mmm bearings for this.
I would add a bearing on the forks, but it would basically be a teeny tiny bearing with at most a 1/4" outer diameter. The thrust bearing cantilevers the bevel gear a lot more than I would like, but I couldn't find a thrust bearing thinner than the one I'm using right now.
The Andymark Swerve & Steer, as well as most coaxial swerve drives, all cantilever their bevel gear. But to handle thrust loads they sometimes just use thrust washers, and none of them cantilever the bearing out as much as I do. I think I'll change to a thrust washer instead of a thrust roller bearing.
Unread 11-08-2015, 02:28
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
how is that connected to the module? it looks like the bent polycarb goes to the CIM housing in the picture, but that doesn't make much sense.
Unread 11-08-2015, 02:40
We would just velcro the polycarb to a convenient spot, in this case, the housing of the CIM. We've found that that works so for mounting encoders, however it is possible to mount it with a tapped plate and standoffs instead. IRL we would not use the CIM for velcro, rather we would mount it to a piece of the chassis or something; the polycarb is only in this model for weight and ascetic purposes.
Unread 11-08-2015, 02:55
R.C.'s Avatar
Gotcha,
If you are using a s4, how are you zero'n it?
http://puu.sh/jxgeU/4eb20e2530.png
Hopefully this shows how we did it, we used the tube axle by VEXpro and used r6-5zz bearings. The forks also had a recess for the tube axle to sit into and it was held in with a 1/4" bolt. We liked this layout but we will be updating the use of the R6-5zz bearings to a metric flanged bearing to retain the wheel better. Atm the wheel can slide off the bevel gear, while it never happened during season it did happen to one of our pbot wheels.
Unsure how thick your forks are as well, we did .5" thick and had room for an 11mm OD bearing. Also used a thrust washer this year, will most likely be switching to a thrust roller bearing.
-RC
R.C.
