#16
Re: paper: DIY 'encoder stage' for VersaPlanetary
#17
What is the limit? Would 10000 cpr at 5krpm work?
#18
Great work. Inspired to look at this sensor for our swerve module. Question. How were the pull up resistor and caps added?
#19
What brand/model of lathe is that? We have been looking for a good one second hand but size is our limiting factor right now :/
#20
It's a Chinese 7x10 similar to Harbor Freight 93212. I've since rebuilt it as a 7x16 with a number of other modifications, but stock it would have been able to do this job just fine. They sell new for $550.
#21
mini-lathe.com is a good resource. The 7x10 is actually only a 7x8 (7" diameter part, 8" max length to be simple) and the 7x12 is an actual 7x12, so it's a good deal to invest in the latter IMO. Craigslist can sometime have good deals, but you should know what you're looking for to do that. Measuring the accuracy is critical. EDIT: In general I would use a mill because of the versatility for FRC, so if it comes down to buying a tool a mill would be my first choice. Last edited by asid61 : 06-09-2015 at 19:08. |
#22
We just posted our version of this modification to our blog.
We haven't got to play around with it to much yet but we did hook it up and check that the system was getting good distance values from the encoder. We made several substitutions to reduce the overall cost of this setup. Each additional gearbox modification for us should only be around $10. |
#23
Thanks for the heads up, I tired a new system for putting the pictures up from google photos but apparently it doesn't actually make them public. Should be fixed now.
#25
Excellent work!
I'd love to see someone (VexPro?!) sell one of these... it'd be really great to not need to make a part year-after-year just because it's not sold when it'd be so widely useful. |
#26
As far as epoxy vs RTV silicone: We were going to use RTV at first, but after a short debate we chose a potting epoxy that my professional colleagues use. The internal magnet(s?) within the Allegro package are quite strong, and when the steel gear is nearby there is a significant attractive force between them. It's probably a dynamic force as the gear rotates. Had we suspended the sensor in a flexible potting compound like RTV, we were worried about the effects of the induced vibration. Last edited by Nate Laverdure : 15-09-2015 at 11:40. |
#27
Sorry I haven't had a chance to read the blog, but that would be a great point to mention in the blog. Many teams probably aren't familiar with the differences in those compounds and if that is an issue, it would be good for them to see it coming and avoid it.
#28
#29
Something like this may be a viable solution if that problem does arise. Last edited by AllenGregoryIV : 15-09-2015 at 12:03. |
#30
This is great. I'm adding it to our projects to try in the off-season. We use VersaPlanetary gearboxes everywhere that we can for their small form factor, ease of use and ability to modify gear ratios as-needed. Integrating sensor feedback into that package would be absolutely huge for a team like ours.
