Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 16-09-2015, 18:25
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: WCD 3 CIM PTO Ball Shifter Render
Originally Posted by Knufire View Post
The newest rev of the ball shifter shaft has the hex pinned instead of pressed.
Originally Posted by Aren_Hill View Post
Pinned AND Pressed.
-Aren
Thank you two for clarifying. However, I am not planning on using the vex shifter shaft.
I think your CIMs aren't supported as well as they could be. It's pretty common in these kind of gearboxes to have a web that follows the diameter of the CIM in order to support the whole face. Right now the little sliver of metal supporting the middle of the CIM may not be substantial / rigid enough. The tiny amount of weight savings isn't really worth risking flex in that area of the gearbox.
Thank you bringing up the question of CIM support. I think your concern is stemming from the fact that there are several aspects of this gearbox that are not easily visible from this angle.
1. The CIM is resting against 0.25" Al along its entire bottom edge.
2. nestled in between the CIM motors are standoffs that run back to support the pneumatic cylinder that runs the PTO. These standoffs will also help support the CIM motor from below.
If that is a stock ballshifter shaft, I would be concerned about direct driving a wheel off of that shaft. It might not be a good idea to load the shaft that way. The hex end of it is just pressed in to the end of the shifter shaft, with about 3/4" of engagement if memory serves. I think this is one reason the COTS direct drive ballshifters have a third gear stage. This does indeed make fitting a ballshifter into a WCD gearbox in 2 stages quite difficult.
For this reason, I have never been a fan of the design of the ball shifter shaft from vex. In this design there are two custom simplified one piece shifter shafts.
I'm working on a similar gearbox for a similar application, and the constraint of using the ball shifter shaft without direct driving off of it is quite annoying. I don't know how feasible this is at all, but have you considered using it backwards? Having the CIMs drive a gear on the output of the shifter shaft, then putting two output gears on the wheel shaft? Might be worth a shot, particularly if you're into the latest WCD fad of hanging your drive motors over the wheels. Probably not a good idea, but something unique to look at.
This is a cool idea in my opinion, Even though it would cause a few problems. The only issues I see with it right now are that it would make gearbox assembly difficult, and cause there to be an unused gap in the gearbox unless the first stage was cantilevered.
FLL Team Future imagineers
FRC Team Mean Machine
