Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 21-09-2015, 11:58
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: pic: Diagonal View
Great job with the CAD work. I can critique the design a bit:
You're going to have all kinds of trouble with the sliding link. A good rule of thumb for sliding joints is that the ratio between bearing length (in the direction of sliding), and bearing diameter (or spacing) should be greater than 2:1, otherwise when one side starts to grip a bit, the whole bearing will twist and jam. You've got hardly any bearing length in this sketch, so jamming would be a real concern.
Another good rule of thumb is to prefer rotating joints to sliding joints - so if you can redesign this to use a trailing arm, you'll have more chance of success.
