Go to Post Every single person on the team, read the manual, cover to cover, NO skimming. Do not give the task of knowing the rules to a few people. Do not pass go, do not collect $200, READ THE MANUAL. - RoboChair [more]
Unread 21-09-2015, 20:46
EricH EricH is offline
Re: pic: Top View
A follower wheel is a common thing, in certain drive systems. (So common that, contrary to popular belief, Lunacy wheels were NOT the only thing allowed to contact the regolith--follower wheels were specifically allowed.)
But, as noted, the standard configuration is two, at right angles, with a gyro for rotation, and usually not on a skid steer (Lunacy being the exception).
And, for some teams, an IMU is even more preferred: two accelerometers at right angles to each other and a gyro. Just needs some calculus.
BTW, a more common configuration of a given follower wheel--and a simpler one, I think--is a small wheel (like a VEX omni, and not a VEXPro omni)on the end of a rotating support structure, slightly spring-loaded so it'll stay in contact with the ground.
