pic: T-Shirt Cannon
Re: pic: T-Shirt Cannon
Very cool! What gearbox are you running? Is this a WCD or a chain in tube?
How are you indexing the barrels? I see some heavy 254 influence in this . |
Oh that's right, I never showed you this b/c I put this on 649's GrabCAD.
I'm using custom 1-cim gearboxes. Reason is that I see no need for using a lot of power on drive ... unless the robot is going uphill. This is a WCD with chain outside the tube. It's kinda hard to see it in the render, but in the tank mounts I made some cuts in order for the chain to pass through to the other sprockets. And barrel indexing is using an encoder (not shown b/c I'm an idiot) and a piston which latches in countersunk holes in the barrel plate (it's the same thing from my first one in TSC-102 in 115's offseason GrabCAD). I've taken a good look at 254's Shockwave at Chezy Champs, and I kind of see how the indexing system works, but I'm still chewing on it ![]() |
