Thread Tools |
Rating:
Display Modes |
Re: pic: T-Shirt Cannon Bot Concept WIP
The valve I'm using for my t-shirt cannon was this:
http://www.ascovalve.com/Application...IsTran sSSL=Y Uh... that's a really long link, but it should direct you to something I found while browsing CD for info on t-shirt cannons. Now what kind of air tanks are those? I'm having some issues finding the right one, and those look really great for my design ![]() |
We used these tanks this past season with success. 1 gal each.
http://www.avsontheweb.com/1-gallon-...-port-fitting/ They have quite a few different sizes. Just search their site for "tank". |
We brought our rebuilt air cannon to Homecoming last night, so I have a few comments, some positive, some questioning:
We built one similar a few years back and having shells preloaded is great for speed or for targeting sponsors (if we see on in the crowd at a football game we can load three in a row that contain their shirts).
We run ours off of CO2, and only at 12 psi for normal operation. We use one $14 tank for around 70-80 shirts. I'll put up a picture soon, the only part we haven't figured out yet is the magazine. I like your solutionwith the rotart loading. We simplified a bit and used a pneumatic ejector and plan to spring load shells so they autoload when the spent shell is ejected. |
That said, the tanks that otherguy posted are only 1in longer and a bit smaller diameter, if this is to be built, something like that would probably be used instead. Quote:
Also, do you have any suggestions for large (~1") ID pneumatic hose? I'm not sure what type to look for or where to look (the only pneumatics I've ever dealt with have come in the FRC kit of parts). Quote:
That said, I'm curious what people think about using PVC for the barrel. It seems to be quite common, and I would think since the barrel isn't really storing air pressure it wouldn't be a problem. People I've proposed this idea to have mixed feelings about PVC despite it being used in literally every example cannon they've showed me. Quote:
Does your cannon (or anyone else reading this) use a 2-stage air system (storage->accumulator), and if so, what is the volume of the accumulator? |
Finally, tee fittings have a pretty significant pressure drop (relatively speaking). When you are discharging air in a cannon, your air flow speed is likely going to be quite high, so having a significant number of tees might be an issue. If they were between your high pressure tank and your accumulator, it wouldn't be an issue, but everything that is "firing" when that valve opens needs to be relatively large with minimal pressure drop. |
This is from a bit of thought, not experience: Fill a tire with air and put a quarter of the robot's weight on it, and see how much the axle drops. I would use at least that much center drop, probably a bit more. Quote:
Rather than change the angle, we are planning to adjust range by changing the duration that we keep the valve open. I believe we're currently hard coded at 50ms, but we now have a more capable controller and will be adding variable timing. Last edited by GeeTwo : 27-09-2015 at 15:25. |
You can find a picture of our semi-semi auto t-shirt cannon here. Apparently when you upload from an Android phone the thumbnail is upside down, but full size is right.
http://www.chiefdelphi.com/media/img...425da706_l.jpg We have since ditched the FRC control system in favor of the Cheap and Dirty control system from Andymark. The FRC system was super unreliable and this one works up to about 350 feet away. For those shopping for a RC system you can find the same thing as AndyMarks without their stickers for less than half the price here. Last edited by MrBasse : 27-09-2015 at 16:20. |
