Go to Post Social life? Ha! Robotics is my social life. :D - Éowyn [more]
Unread 29-09-2015, 08:26
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: T-Shirt Cannon Bot Concept WIP
Originally Posted by Kyle Butzerin View Post
Are there valves that will release the stored air we need to propel the shirt through a 4" barrel without modification? If so, what can you suggest?
Look on Google. We use one similar to this. If you can find one that's a bit larger (1" or 1-1/4"), even better. The most important thing is that the valve (and plumbing and tank and fittings and so forth) is rated for air, at a higher pressure than you're using. A large valve (3/4 NPT or greater) is essential to get enough air out fast enough to throw a t-shirt very far without using pressures higher than we're used to in FRC.
I don't know what takk you have in the model, and we don't move our barrel vertically, but control range using the time the valve is open, so I'll pass on the other two questions.
