Go to Post Look past the robot. Look past your team. Science and technolgy are studies worth devoting your life too. - KenWittlief [more]
Unread 30-09-2015, 19:31
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: Tiki Techs - FRC 2015 Robot
Originally Posted by BBray_T1296 View Post
Yes, but they cannot have anything to do with actuation. IE no PWM/relay/can/etc control over motors.
They can collect sensor data (such as camera or otherwise) and perform computation to offload roboRIO resources though.
Originally Posted by 2015 manual 4.8-R44
CUSTOM CIRCUITS shall not directly alter the power pathways between the ROBOT battery, PDP, motor controllers, relays,
motors and actuators (per R18), pneumatic solenoid valves, or other elements of the ROBOT control system (items explicitly mentioned in R55). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the
ROBOT’S electrical system is acceptable, if the effect on the ROBOT outputs is inconsequential.
An arduino/equiv is considered a custom circuit.
Obligatory "this year's rules aren't necessarily next year's" but this rule has been in here for a while.
