Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 30-09-2015, 21:25
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: Tiki Techs - FRC 2015 Robot
Originally Posted by EDesbiens View Post
Cool, thanks, didn't know about the sensor part... So we can connect the outpout and input pins of a micro-controller to the robot-rio? And is it simple to program?
I have exactly zero experience programming these things. I'd imagine it would be easier to communicate via the USB port or ethernet (or perhaps even CAN), though there is no reason the DIO wouldn't be allowed
Usually teams use independent boards for vision processing. Normal sensors usually take only a tiny fraction of CPU power. Also note that if you are using a Talon SRX with CAN, sensors can be plugged into the breakout board for the motor controllers (which may be in a more convenient location [like our tether-bot this year]) and the roboRIO can read those sensors over the CAN line
