Go to Post It's not about the robot. It's about science, technology, engineering, and mathematics. - Ether [more]
Unread 10-07-2015, 12:13 AM
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Re: pic: FTC Custom Drive Train
Originally Posted by IceStorm View Post
thanks for the cad file. and the explanation of it. do you see any reason this wouldn't work with the #35 sprockets from vex pro?
-Chad
I don't see a reason why it wouldn't work, but I'd probably go with a couple of the #25 sprockets instead of one of the #35 doubles. I'm pretty sure buying an adapter plus two of the VexPro sprockets is cheaper than getting a single sprockets from AM or Tetrix (although I suppose those have the advantage of just dropping in).
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 10-07-2015, 10:22 AM
Knufire Knufire is online now
The biggest advantage of the AM sprocket is not having to rely on a set screw to transmit torque from the motor output shaft. AM found the slit + collar clamp method that IceStorm mentioned to be more reliable, which is what that sprocket operates on.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
