Re: pic: Inverted CIM 2-Speed Gearbox
School A: -Low gear is intended for pushing matches, and in some cases fine movement (e.g. bridge balancing in 2012). You want this gear to be traction limited such that the wheel slip condition (which is when torque the output from the gearbox overcomes the static friction of the wheels on the floor) occurs around or below 40 A per motor. With 6 CIMs, you might need to begin to consider the Main Breaker 120 A limit, but be sure to check out the spec sheet and understand how long your breaker will last at max current for the drive train. -High gear is what you use at all times when you're doing anything other than pushing an opponent or doing fine motion which is less effective at a higher speed. The aim should be to minimize the travel time for a given sprint distance that aligns with your style of game play. It's nice if this is traction limited, but don't lose too much sleep over the actual current draw numbers at your traction limit since you should never hit those with good, practiced driving. School B: -Low gear is intended for completing game objectives with a short sprint distance, and again some fine movement tasks. The gearing should be chosen to optimize that sprint distance. You want this gear to be traction limited such that the wheel slip condition (which is when torque the output from the gearbox overcomes the static friction of the wheels on the floor) occurs at some value which will allow you to be in a pushing match for some amount of time. You will also use this gear when in pushing matches. -High gear is is intended for completing game objectives with a farther sprint distance. The aim should again be to minimize the travel time for a given sprint distance that aligns with your style of game play. Similarly to School A, it's nice if this is traction limited, but don't lose too much sleep over the actual current draw numbers at your traction limit since you should never hit those with good, practiced driving. The merit to School A is that it's often easier on the drivers to have a simple dichotomy of which gear to use when. When you're mindset is "Pushing match = low gear, Every other situation = high gear", it's hard to go wrong. It is also good peace of mind to never worry about losing power during a pushing match, especially in years like 2014 (well...almost never ). Chris is spot on with his 6 ft/s suggestion if your design objectives align with School A. Depending on your efficiency and your CoF, 5-7 ft/s is a general range that gets you down to 40 A per motor at your traction limit for a full weight robot with battery and bumpers.If my memory serves me correctly, one example of a School B design is the Killer Bees' robot in 2013. Their robot was a floor pick up machine and would often times pick up discs from the floor during teleop if the opportunity presented itself. However, there weren't always discs on the floor. In that case they would drive to the opposite end of the field to get discs from the feeder station. Playing the floor pickup role was a short sprint distance objective, and playing the feeder station role was a longer distance objective. They couldn't necessarily know going into each match what role they would play, and sometimes it would change throughout the match, so having a separate drive train gear ratio for each style of play was an elegant solution. It seemed to work well, they were World Finalists after all. In general, drive train gearing is a trade-off between how long it takes you to go from point A to point B and how much current you're pushing through your breakers. When going above about 15 ft/s, you start to reduce your pushing force and initial acceleration in high gear at the expense of additional top speed (assuming a full weight robot plus battery and bumpers). |
I thought 33 2013's robot used shifitng for improved acceleration with their autoshift code.
I'm not crazy about the tiny idler gear - seems like it'd wear very quickly and as a result become a detriment to efficiency as the season went on. Is that the largest gear you can get for that initial stage?
As a result - School A needs the best high-traction treads available to maximise performance in the situations the design is made for. - School B needs tread that WILL slip under enough torque so as to not trip the breakers. Colsons fit that spec nicely, imo. |
I've found colsons tend to be rather grippy if you're aiming for slippage under high traction. Something like sky wheels or the white KOP wheels would work better IMO.
I plan on making another gearbox of a similar design, and perhaps take a look at Andymark dog gears, which come in smaller diameters, so hopefully that will eliminate the need for dog gears. Quote:
Hopefully this is the right way to go if I'm going for a maneuverable and defensive bot? |
If it weren't for the emoji, I'd have to report you for trolling. My right eye is twitching, even though I never heard of FRC until April or May of 2011.
I would not be surprised at all to hear that they incorporated autoshifting in 2013, given that they developed a 4-speed autoshifting drive train and code as far back as 2004. However, the logic for gear ratio selection for autoshifting would still probably be consistent with the thought of having good sprint distance for both floor pick up and cycling. Maybe someone from Killer Bees could fill us in with more details? Interesting...I would have classified 2014 into School A given the prevalence of defense and the fact that just about every team would be playing D at one point or another. That is to say, sustaining a pushing match for 15+ seconds would be more valuable than shaving a few tenths of a second off of a 10 foot sprint. But like we were saying before, depends on which criteria you're aiming to meet. |
#10
It seemed to me that the better defense for 2014 was a 'pillaring' technique. Pillaring is a tank warfare term, where the tank drives back & forth perpendicular to the cannon's aim. It requires planning & setup, but it makes the tank much harder to hit while making it relatively easy for it to maintain sighting on a target. This is prevalent in the Battlefield series of games. This same concept works for defense on the FRC field. Sprint into position, then pillar back/forth and force the other team to either push you sideways or drive fast enough around you to get to their goal. The likelyhood of them pushing you is high - yet it's time consuming and usually not as effective as one would thing since it still doesn't solve the problem of them getting to their desired spot for an open shot. Faster low gear speeds on an open field also give more opportunities to clip/turn a corner of a shooting bot - much more effective than raw pushing. |
#11
In 2014, pushing was much less risky as there were no safe zones. T-bone pinning a robot had a bit more risk than "pillaring" but a lot more benefit - the robot is essentially immobile for the duration of the pin. I don't think "pillaring" was definitively better in 2014 just because of the T-bone pin and the relatively wide space to drive around. It is an important part of a defensive strategy but not the end-all. |
#12
Do (e.g.) sailcloth bumpers change this consideration at all? This plays into the original topic a bit - shaft spacing is usually determined by the gear availability and the desired difference between high gear and low gear (e.g. the dog gear choices). School A wants a larger gearing difference, School B wants a smaller gearing difference. |
#13
