Go to Post See what you don't understand about us students is that we don't know when to stop. - ehfeinberg [more]
Unread 12-10-2015, 20:56
FRC #1836 (MilkenKnights)
Re: pic: Inverted CIM 2-Speed Gearbox
Originally Posted by KohKohPuffs View Post
So the main purpose of the idler gear is to get the gear space in between the CIMs because the way the gearbox is designed. If we do end up doing idler gears, then we could just replace them with new ones if they ever wear down. On the other hand, the big gear is a 72T gear, so I might be able to replace it with an 84T and remove the idlers. However, I remember on another gearbox I was working with another person, we had trouble with the gear sizes with an 84T.
Switching to belts might be a good solution here. Plus, you'd get a nice efficiency boost.
