Go to Post why re-invent the wheel when it still rolls? just make it better. - Tytus Gerrish [more]
Unread 13-10-2015, 10:30
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Re: pic: 2015/2016 Robot Radio Comparison
Originally Posted by Foster View Post
I've used these Adafruit power injector adaptors in the past. It would give you the one cable run ability at the risk of some extra connections.
The connections use the snap on the ethernet cable to hold them in place, I've not had problems with them coming apart in daily use.
I'm not sure if they would run into a power rule problem, maybe Al can give some guidance.
R32 is what will prevent you from doing this. It says you must power the radio from the VRM.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
