Go to Post The season ended. Not cool. - Koko Ed [more]
Unread 13-10-2015, 10:57
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: pic: 2015/2016 Robot Radio Comparison
Originally Posted by orangemoore View Post
R32 is what will prevent you from doing this. It says you must power the radio from the VRM.
Why would that rule prevent the use of POE injectors? You could easily power the injector from the VRM.
The rule that I see being a problem is R38. It says that regulated circuits < 5A should be wired with 22AWG wire. You can find 22 gauge ethernet cable, but it's not very common.
