Go to Post In the 2010 game, FRC and FVC robots will be working together to cut Dave's hair, mow his lawn, and serve him dinner. ;) - Rich Kressly [more]
Unread 14-10-2015, 07:54
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: pic: Inverted CIM 2-Speed Gearbox
As a student machinist for my team, I would recommend against making gears if you can avoid it at all. Indexing and cutting 2-3 times per tooth takes a very long time, not to mention all the work of taking a vise off the table for an indexing head or rotary table and centering everything. If you have the resources, go for it, but personally I can think of few situations where you would really want to do that (a 26t or 16t gear being those few situations ). I've designed swerve drives that can be manually machined, but not ones that you would really want to.
Buying spur gear stock or something similar would be good for making many custom gears.
I also do not recommend machining your own gears unless you have the time. I have been using Martin spur gears and modifying the hubs as needed. They come in almost every gear size and are available on line and from McMaster.
Andy Brockway
Team 716, The Who'sCTEKS
