Re: pic: Inverted CIM 2-Speed Gearbox
For a 150 lb robot with roughtop tread, that "magic number" is around 6 feet per second, depending on your efficiency, exact weight, wheel design, etc. |
This will be a new design (but I'm keeping the inverted CIMs), since to do this I had to have the dog gears be the driven gears rather than the driving gears in the second stage (shifting on upper shaft). Also, in order to have the gear space in the gearbox, I'm most likely going to keep the idlers:
Thoughts? |
Removing the idlers can only do you good, regardless of wearing out. Reduces complexity and weight. If you have to keep them, that makes sense, but I would remove them if at all possible. What are you guys moving away from belts for? The epitome of flipped-cim gearboxes (192 in 2014) used belts for their first stage and it reportedly went swimmingly. Saves a lot of weight and space in these things IME. |
I mean... this only applies to the chassis, so perhaps I would attempt a belt system for the first stage. However, I'm using a large ratio for that stage, so I'm not even sure if there are the right pulleys for my configuration. -Is there an online store that specializes in pulleys? It's been a while since I last been there, and my memory is fading away... -_- -Also, is it possible to make your own pulleys? If so, is there a link to how to do that? |
