Go to Post Best way to get the word out for FIRST is Demo, Demo, Demo. There's no reason anyone in your community shouldn't know what you folks are doing. - Martinez [more]
Unread 15-10-2015, 01:43
Re: pic: Inverted CIM 2-Speed Gearbox
Originally Posted by KohKohPuffs View Post
I've been punching some numbers into JVN design calculator, and I managed 16.85fps high, and 6.76fps low.
This will be a new design (but I'm keeping the inverted CIMs), since to do this I had to have the dog gears be the driven gears rather than the driving gears in the second stage (shifting on upper shaft). Also, in order to have the gear space in the gearbox, I'm most likely going to keep the idlers:
  1. The idler gears are easily replacable in case they wear out
  2. Using my logic, the idler gears are made of steel, so I doubt wearing down is going to be significant
As for a belted gearbox, I think our team wants to move away from belts. It's a bit complicated, but even if it is better than idlers, I'd rather work on the current style I have going.
Thoughts?
Those speeds are much better, you should be able to withstand a pushing match for a least a little while (I'm getting about 50A current draw with 4.2" wheels, 150lbs, and 1.3 CoF).
Removing the idlers can only do you good, regardless of wearing out. Reduces complexity and weight. If you have to keep them, that makes sense, but I would remove them if at all possible.
What are you guys moving away from belts for? The epitome of flipped-cim gearboxes (192 in 2014) used belts for their first stage and it reportedly went swimmingly. Saves a lot of weight and space in these things IME.
Unread 15-10-2015, 01:51
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
I might be completely wrong about my team and belts, but we've been using belts for a while on our DT, and this offseason we're experimenting with chain DTs.
I mean... this only applies to the chassis, so perhaps I would attempt a belt system for the first stage. However, I'm using a large ratio for that stage, so I'm not even sure if there are the right pulleys for my configuration.
-Is there an online store that specializes in pulleys? It's been a while since I last been there, and my memory is fading away... -_-
-Also, is it possible to make your own pulleys? If so, is there a link to how to do that?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
Unread 15-10-2015, 02:02
SDP-SI has them, but seeing that in this case you have a very large reduction you wouldn't be able to pull it off and still maintain adequate belt wrap without idlers.
Naveed Riaziat's Avatar
Naveed Riaziat Naveed Riaziat is offline
FRC #0649
Naveed Riaziat is an unknown quantity at this point
We are moving away from belt in drivetrains because the tenioning was too much work for the benefit. However, tensioning similar to 192's 2014 gearbox is feasible, and in fact, 649 has cadded a similar idea already. It might be tough to get such a large first reduction however with belt. SDP-SI is basically the go-to for pulleys, and 649 already does make their own pulleys, either through our laser cutter or through our wire-edm sponsor.
