Go to Post Although I have much yet to go, in my short time in FIRST I have learned there is no such thing as a waste of time, especially when a) fundraising, b) mentoring students, or c) reading directions. - Amanda Morrison [more]
Unread 15-10-2015, 01:51
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Re: pic: Inverted CIM 2-Speed Gearbox
Those speeds are much better, you should be able to withstand a pushing match for a least a little while (I'm getting about 50A current draw with 4.2" wheels, 150lbs, and 1.3 CoF).
Removing the idlers can only do you good, regardless of wearing out. Reduces complexity and weight. If you have to keep them, that makes sense, but I would remove them if at all possible.
What are you guys moving away from belts for? The epitome of flipped-cim gearboxes (192 in 2014) used belts for their first stage and it reportedly went swimmingly. Saves a lot of weight and space in these things IME.
I might be completely wrong about my team and belts, but we've been using belts for a while on our DT, and this offseason we're experimenting with chain DTs.
I mean... this only applies to the chassis, so perhaps I would attempt a belt system for the first stage. However, I'm using a large ratio for that stage, so I'm not even sure if there are the right pulleys for my configuration.
-Is there an online store that specializes in pulleys? It's been a while since I last been there, and my memory is fading away... -_-
-Also, is it possible to make your own pulleys? If so, is there a link to how to do that?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
Unread 15-10-2015, 02:02
SDP-SI has them, but seeing that in this case you have a very large reduction you wouldn't be able to pull it off and still maintain adequate belt wrap without idlers.
Naveed Riaziat's Avatar
Naveed Riaziat Naveed Riaziat is offline
FRC #0649
Naveed Riaziat is an unknown quantity at this point
We are moving away from belt in drivetrains because the tenioning was too much work for the benefit. However, tensioning similar to 192's 2014 gearbox is feasible, and in fact, 649 has cadded a similar idea already. It might be tough to get such a large first reduction however with belt. SDP-SI is basically the go-to for pulleys, and 649 already does make their own pulleys, either through our laser cutter or through our wire-edm sponsor.
