Go to Post Nats allows an exchange of a vast multitude of ideas from everywhere. Not only in robot design, but accents, tool storage, pit design, team spirt, clothing, many things. - Wetzel [more]
Unread 15-10-2015, 02:02
Naveed Riaziat's Avatar
Naveed Riaziat Naveed Riaziat is offline
FRC #0649
Naveed Riaziat is an unknown quantity at this point
Re: pic: Inverted CIM 2-Speed Gearbox
Originally Posted by KohKohPuffs View Post
I might be completely wrong about my team and belts, but we've been using belts for a while on our DT, and this offseason we're experimenting with chain DTs.
I mean... this only applies to the chassis, so perhaps I would attempt a belt system for the first stage. However, I'm using a large ratio for that stage, so I'm not even sure if there are the right pulleys for my configuration.
-Is there an online store that specializes in pulleys? It's been a while since I last been there, and my memory is fading away... -_-
-Also, is it possible to make your own pulleys? If so, is there a link to how to do that?
We are moving away from belt in drivetrains because the tenioning was too much work for the benefit. However, tensioning similar to 192's 2014 gearbox is feasible, and in fact, 649 has cadded a similar idea already. It might be tough to get such a large first reduction however with belt. SDP-SI is basically the go-to for pulleys, and 649 already does make their own pulleys, either through our laser cutter or through our wire-edm sponsor.
