Go to Post Girls, if you are techy, great! If you're not, don't worry about it. We're all good at something and FIRST can show you what that is. Just remember, be true to WHO YOU ARE. - Erin Rapacki [more]
Unread 20-10-2015, 13:00
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
pic: Team 5413 Stellar Robotics Offseason Drivetrain
Unread 20-10-2015, 13:01
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: pic: Team 5413 Stellar Robotics Offseason Drivetrain
Good work! This looks great!
Have you considered adding a third CIM to the gearboxes? Seems like it could be modified pretty easily. Also, are you doing anything to integrate a sensor like an encoder into the drive train?
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 20-10-2015, 14:44
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Looks really clean good work. I also have a few questions about it.
Is the angle at the bottom of the base when looking at it from a side-view there for a reason? (i.e. going over bumps) If there is no reason Other than aesthetics your frames strength can be increased by extending the flanges out to make them square with little weight added. Right now the bottom plane of the base looks like its only able to get one fastener in each corner. That means that that whole plain wants to fold in on itself if hit correctly. On the top you have the ability to put more than one fastener in which stops this folding motion from happening. I am not saying it will fail, in fact it would probably be fine, but it would make it stronger if you extended them out to complete the box.
If it is there for a reason, there are a few other things you can do that would make it stronger as well. If you added a belly pan to the bottom plane of the base it would perform two functions that i think would improve the overall design. Its nice because it would add a place for you to mount electronics too as well as act as a sheer plate and prevent that folding from wanting to occur.
Just some things to consider. Good work last season! We had fun playing against you guys at buckeye. Hopefully some day we can end up on the same side of the glass. You were excellent especially considering it was your rookie year. Keep it up!
Unread 20-10-2015, 15:21
I really admire the minimalist simplicity of this design. Exactly everything a drive base needs and nothing more - nothing overly flashy.
I think your drop is a little severe especially for a 31x27 chassis. The .125" drop-center standard was crafted in the 38x28 era, and on my last robot of similar dimensions with Colson wheels I thought it was just a bit too much rock. 1/16" or even zero drop would probably work well. I don't think it's really going to hurt your performance one way or another though.
Do you have a system to tension the chain when / if it stretches?
The integrated gearbox is great for reducing part count but not so great for serviceability and relies on your sheet metal shop's hole tolerances being as good as your milled plate tolerances. You also have less ability to redesign if something goes wrong. I would switch to a 2-plate gearbox just out of paranoia more than anything else.
Any plans for a belly pan? You could really use one for rigidity? You have very little cross bracing.
Unread 20-10-2015, 17:56
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Another question did you laser and stack that 60t gear? I would personally buy a vexpro al gear since it's 7075 AL and the tooth profile will last much longer.
If you'd really like to keep it lasered I'd switch to 6061 and make it .5 to .75 thick aka match the full width of a vp 12t.
R.C.
MadTown Robotics Team 1323
Unread 20-10-2015, 19:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
While it's not a real answer, you can see that there are four screw heads around each wheel shaft. This implies that there are actual bearing blocks on the other side of each plate, which may be adjustable.
Every bearing is (or should be) mounted in a block, not a plate. There is no need for a bearing where the main drive shaft passes through the inner plate, as it is supported by a bearing in the motor mount plate at one end and a bearing block screwed to the outer plate at the other end.
At first glance, I thought that you'd built an AM14U, then saw that the top folds were more like the U2, then noticed the gearbox and chain mounted inboard of the wheels rather than belts on both sides of the wheels, then the bearing block mounts. If you're ready to run a game with a single-speed 5:1 gearbox, this seems to combine the rugged battle tested design of the recent kit with some optimizations to reduce the footprint consumed by the belts/chains, and move the wheels farther out. I also like the complete "skateboard" capability that the recent kitbot lacks - if you put the control system (and perhaps battery) inside the volume defined by the inner rails, you have a level surface upon which to build your manipulators. By perforating every 1", you have plenty of mount points as you make adjustments. It's also a natural to mount a VersaFrame superstructure.
I would also recommend a belly pan, both for torsion control and for mounting your controls. Considering the belly pan makes me wonder - why are the bottom folds on the inner plate outboard towards the wheels, rather than inboard? If you put them inboard, you could mount your bellypan/control panel there. Likewise, if your top folds bent outboard rather than inboard, they would tend to act as chain guards rather than restricting access to the volume between the inner plates where (if you put your control system low), you are going to want to go. Or perhaps you are planning to mount the control panel/torsion control panel to the TOP of this chassis, and accept that when you need to work on the control system, you're going to lay the robot on a side/end/top so that you can access it from the side that normally faces the carpet?
Edit: I can imagine a truly elegant battery box that's accessed from below, in which the battery is held in place at one end by the front or rear plate, and an angle bracket keeps the battery from sliding away from that end plate or dropping onto the carpet.
Unread 20-10-2015, 20:08
Except the same four bolt pattern is present at the stationary, center wheel, implying a stationary block of some sort.
You don't need a bearing there (and having more than two bearings per shaft can be a pretty bad idea in general), but I don't see how this has much of anything to do with whether or not an integral versus separable gearbox is a good idea.
Unread 21-10-2015, 00:56
You will stiffen up your frame dramatically if you connect the two plates in each drive side. We always connect up the box sides. As others have mentioned a bellypan will add significant rigidity as well.
Looks like a solid start!
Unread 21-10-2015, 01:24
RoboticDaymon's Avatar
RoboticDaymon RoboticDaymon is offline
AKA: Daymon W.
FRC #2403 (Plasma Robotics)
RoboticDaymon is an unknown quantity at this point
Well I cant speak for the team but if you look very closely at the outside blocks there appears to be slots cut in the metal around where the bolt go through. I would guess that this would make those blocks able to slide to tension the chain. But without the original designer posting about it I cant be sure. Just looks like that to me.
Plasma Robotics 2403 (Student 2013-2016)
CAD, Mechanical, Strategy, and Scouting
2016 - Arizona West Regional Chairman's Award
2015 - Arizona West Regional Finalists and AIA State Championship 3rd Place Alliance
2014 - Arizona Regional Winner and Engineering Inspiration Award
2013 - Las Vegas Regional Finalist and Engineering Inspiration Award
Unread 21-10-2015, 16:16
Great catch, I couldn't load a hi res picture earlier and missed that entirely.
In that case, I would maybe be concerned about "toe-in" on the bearing blocks, where human error results in the blocks not being perfectly concentric / aligned, hurting efficiency. But that fear is probably not a huge concern since a lot of teams do this without problems.
Unread 21-10-2015, 20:21
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I was mostly addressing the point that it:
..relies on your sheet metal shop's hole tolerances being as good as your milled plate tolerances.
That is, using adjustable bearing blocks allows compensation for coarser hole placement tolerances in the chassis plates.
Unread 21-10-2015, 21:16
First of all, thanks for all the great feedback! This stuff really helps to make a design better on the next iteration.
I'm going to try to answer all of questions. Let me know if I missed any. Answers:
3rd CIM - Yes, we could add a third CIM very easily. There are a lot of threads about the pros and cons on 3-CIM drivetrains. Personally I'm not a fan of them, but the team might choose to do one if the game really required it.
Encoder - We decided not to add an encoder to the offseason drivetrain, but the design would be adapted to place the encoder above the CIMs (where a third motor would go) or out in front of the gearbox. It would be driven on its own shaft driven by a belt or gear.
Front profile - The front bevel is for avoiding obstacles. We decided to try it in order to get a feel for the tolerances on the bends. If it wasn't needed for the game we would just make it square and move the wheels forward a bit.
Belly pan - Yes, we just haven't put it in yet.
Center drop - The 2014 kitbot had a .125 and it couldn't turn worth anything. The 2015 kitbot has increased drop and it didn't have any problem turning. We decided to go with a large drop to replicate that. We are using different wheels though, so we'll see how much that plays in (probably a lot).
Tensioning - The corner bearing blocks are mounted on slots.
60 tooth gear - Yes, it's laser-cut and stacked. The 60 tooth gears are on backorder from WCP so we had to do something in the meantime. Overall they work pretty well. We will swap them out when the gears come in.
Gearbox configuration - I'm not 100% sure how this is less serviceable than a typical gearbox. Four nuts hold the plate on and everything else sides off once that's off. There is plenty of room for tools where needed.
Flanges - I kinda missed the boat on putting the inside flanges inward for the belly pan. It was pretty much just an oversight. That'll be on the next iteration I guess.
Electronics placement - On this design we will be mounting the electronics on the belly pan in a typical configuration. I have always liked the idea of an inverted electronics board. This drivetrain is actually based off of a design I did a while back which had an inverted electronics board. If I remember, I'll post some pictures.
Once again, thanks for the feedback. If I missed anything, let me know.
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 21-10-2015, 22:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
To clarify, do you mean that electronics are accessed from the side of the robot that normally faces the carpet? If so, you will probably want to arrange your cart so that the robot is normally transported in a horizontal configuration compared to its competition vertical configuration. This was not really an option for many 2015 robots, as they were taller than 45" in competition configuration.
Unread 21-10-2015, 23:39
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
For your first custom drivebase this looks very good. Love the simplicity in the gearbox with the weight and space savings of just putting in what you need.
You have so many options available when doing a custom drivebase. Throw in the mounting holes for a few other COTs gearboxes so if you want to move to an off the shelf shifting or single speed option you have the ability to do so pain free. In 2014 we machined our plates to accommodate three different gearboxes so if we weren't impressed by our first option we make a mid season swap. All it takes was a few minutes to add the holes.
As for the drop, if you are using Colsons you can always shave them down on a lathe to tune the drop if its too much or too little.
Looks great!
Unread 22-10-2015, 00:10
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Could you explain your reasoning on this? I can definitely see wanting to have the robot easily moved to an electronics-accessible position in the pit or in queue, but can't see the benefit of transporting it in that configuration.
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
