Go to Post Let's all try to get along, it isn't that complicated. - Joe Johnson [more]
Unread 24-10-2015, 15:51
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: pic: Seen at Fall Classic: Side
Is that back omni wheel powered? It is hard to tell from the picture, but would make most sense if it was powered.
Unread 24-10-2015, 16:15
EricH EricH is online now
All wheels are powered.
Some of the chain runs actually drive the lift.
Unread 24-10-2015, 19:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I LIKE IT!
Seems like the U-drive concept is popping up all over this off-season (third I've seen posted, including my own), but this one definitely takes it to a new level, especially when it comes to controlling unintended torque, and also in wrapping around the game piece.
Are those chains or belts running to the back? Are the motors all the way back with the strafe wheel? That looks like too much slack.
Unread 24-10-2015, 23:27
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
I'm trying to understand the overall benefit of this configuration vs a standard mecanum setup or even front mecanum back 2 omni. Surely this config is not favorable in traction with only minimal benefit to powered rotation. Weight reduction (3 gearboxes vs 4)?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 24-10-2015, 23:53
Three points of contact is deterministic at least and makes a suspension not needed to handle ramps such as this year properly.
Unread 25-10-2015, 01:09
Chains. Not all of them are for drive. I forget exactly where the team put their other drive motors--the outer ones look like the lift chains. (Of note: the midships gearboxes change chain direction to operate a lift, and are not part of the drivetrain. Unfortunately, they didn't quite have the time to get that fully operational.)
Edit: Just for the record, I'm not affiliated with the team. But after seeing that... Well, here's the result. I'll have to see if I can signal one or two of the 585 folks to describe it in more detail. As I said in the description, I've never seen a drive like this before.
Unread 25-10-2015, 14:39
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Yes, that's part of it. It also reduces the amount of width and machining that would be needed to mount rotated omni wheels to produce a kiwi. The angles between the forces of adjacent wheels here are 90- 135-135 as opposed to 120-120-120 for kiwi, but it should be close enough to work after some tweaks to the inverse kinematics.
A peculiar thing I just noticed after mentioning kinematics is that the robot can deliver more drive force in the direction transverse to the direction it picks up totes than in the direction parallel to the totes, by a factor of about 1.7 for equal loading on each wheel, more or less as the CoG moves. This means that when you want to cover ground, you'll want to think of the long edges as the front/back, and the open and closed short edges as the sides.
Edit: If this drive style does not yet have a name, I dub it Meckiwi.
Unread 25-10-2015, 14:50
Connor McBride's Avatar
Connor McBride Connor McBride is offline
I live my life 2:30 at a time!
FRC #0166 (Chop Shop)
Connor McBride will become famous soon enough
I noticed that there are manipulators on the robot. How did it perform at the event? were there any break downs and if so, what were they?
FRC 166 2013-2016 (student) 2016-present (junior mentor)
NHTI VEX U 2016-present (treasurer)
Youtube Channel Team Page Facebook Page
Unread 25-10-2015, 18:48
Honestly, I don't remember much, particularly as far as breakdowns. (Though there was that one wire that needed to be taped into place...) Performance was decent, not spectacular--about what a kitbot could do. I don't recall seeing the lift lift anything, though it did at one point snag a tote.
Unread 26-10-2015, 15:27
EmileH's Avatar
EmileH EmileH is online now
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Anyone have video of it in action?
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 26-10-2015, 16:06
It would be interesting to see video of the drive in action, especially considering it didn't have to deal with a changing center of gravity w.r.t. totes. A closed frame design may alleviate some of the challenges with the long chain runs.
For a game with exclusion/safe zones, this setup could be interesting for specific robots - like 2012/2013, if you discount the balancing in 2012. Or even perhaps for a 2014 robot with a specific team/strategy mindset - after all, the Killer Bees proved all-omni was plausible in a defense-heavy game.
I'm all for reducing the number of wheels required to play
Unread 26-10-2015, 17:09
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Off topic, but what 33 actually demonstrated is that floating like a butterfly can be a winning tactic, IF you can also sting like a bee.* This requires a very good driver. Which they had.
Muhammad Ali demonstrated the same thing 40 years earlier, in a different sport.
Richard Wallace
since 2003
Unread 26-10-2015, 21:06
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
You also have to be pretty doing it...
Unread 26-10-2015, 19:59
Doesn't look like it, but I do know there was a stream, and I'm pretty sure the stream was saved. It's just that finding it is going to be interesting.
Unread 29-10-2015, 00:59
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
Is that a cut resin or polymer or is it poured? How heavy?
