Re: pic: Seen at Fall Classic: Side
A peculiar thing I just noticed after mentioning kinematics is that the robot can deliver more drive force in the direction transverse to the direction it picks up totes than in the direction parallel to the totes, by a factor of about 1.7 for equal loading on each wheel, more or less as the CoG moves. This means that when you want to cover ground, you'll want to think of the long edges as the front/back, and the open and closed short edges as the sides. Edit: If this drive style does not yet have a name, I dub it Meckiwi. Last edited by GeeTwo : 25-10-2015 at 21:30. |
I noticed that there are manipulators on the robot. How did it perform at the event? were there any break downs and if so, what were they?
Honestly, I don't remember much, particularly as far as breakdowns. (Though there was that one wire that needed to be taped into place...) Performance was decent, not spectacular--about what a kitbot could do. I don't recall seeing the lift lift anything, though it did at one point snag a tote.
Anyone have video of it in action?
It would be interesting to see video of the drive in action, especially considering it didn't have to deal with a changing center of gravity w.r.t. totes. A closed frame design may alleviate some of the challenges with the long chain runs.
For a game with exclusion/safe zones, this setup could be interesting for specific robots - like 2012/2013, if you discount the balancing in 2012. Or even perhaps for a 2014 robot with a specific team/strategy mindset - after all, the Killer Bees proved all-omni was plausible in a defense-heavy game. I'm all for reducing the number of wheels required to play ![]() |
-------- Muhammad Ali demonstrated the same thing 40 years earlier, in a different sport. |
Doesn't look like it, but I do know there was a stream, and I'm pretty sure the stream was saved. It's just that finding it is going to be interesting.
Is that a cut resin or polymer or is it poured? How heavy?
#10
I'd have to ask the team. It's not poured, I don't think--you don't pour fiberglass. Heavy... I'd say that the main reason this particular robot needs a 2-person carry is awkwardness rather than weight. Try an easy pickup of one end with one hand.
