Originally Posted by philso
Is the "Brake/Coast Mode" next to the positive power input terminal an LED or one of those tiny rotary switches?
It is a button that is accessible through a small hole. A bent paperclip works well.
Is the enclosure fully isolated or is there a metal pad on the back that is at some voltage potential?
The enclosure and heat sink are fully isolated.
Does the PWM input connect directly to an optocoupler LED or does it have a current limiting resistor in series with the LED? We have had trouble connecting several motor controllers of different types to the same PWM signal because the optocoupler LED's had different forward voltages and only the controller with the lowest VF would actually run.
There is a resistor in series with the optocoupler LED.
Thanks for your questions!
