Re: pic: Poly-carbonate 2 Speed Gearbox
I'm not going to comment on the mechanics of the gearbox because there are a lot of people on here more qualified to debate that than I am.
I just have two questions: 1) How much does it weigh? 2) Do you have any plans to cover the very exposed gears to protect dust and fingers from getting stuck in there and jamming it up? |
http://www.andymark.com/product-p/am-0957.htm http://www.vexrobotics.com/vexpro/mo...es/wcp-ds.html http://www.team221.com/viewproduct.php?id=100 |
Very nice.
However, you're going to want to watch out for possible deformation of the plates under load, especially the plate that CIMs are mounted to. |
If you want to be extra safe against deformation, you'll want to upgrade to 3/8ths polycarbonate. 1/4" probably deflects too much, even un-lightened.
It doesn't end up saving you weight over an optimized aluminum gearbox, but it's hard to do gearboxes with polycarbonate. |
You might also consider mounting another plate of polycarbonate between the gearbox and the output sprocket. Having less distance between plates should improve the rigidity. This is what we built a few years back. Note that the aluminum plate was eventually replaced with polycarbonate. Also worth noting that the gearbox is still around 8 years later. The gears failed a while back, but the box is still in great shape. Last edited by cbale2000 : 30-10-2015 at 21:27. |
Very nice, I've been researching good plastics for gearboxes and found that acetal and thick polycarb will work fine, but polycarb does have more flex in it. I'd recommend some sort of bracing/stand for the cims to hold them in place during load (as said above).
Also, 254 has made a plastic-based gearbox and made their mounting frames out of acetal. |
If you could do a stress test on the holes compared to the WCP gearbox plates, that would be interesting to see.
It wasn't worth it though and I'm pretty sure the solid delrin plate was just about as heavy as a pocketed aluminum plate...and substantially less rigid.
We did a test with the same gearbox under the same load using pocketed aluminum plate. It resulted in having a cooler motor over the same testing duration. |
