Go to Post This looks like a job for duct tape! - JoeXIII'007 [more]
Unread 30-10-2015, 12:01
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Re: pic: Poly-carbonate 2 Speed Gearbox
Very nice.
However, you're going to want to watch out for possible deformation of the plates under load, especially the plate that CIMs are mounted to.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 30-10-2015, 12:16
If you want to be extra safe against deformation, you'll want to upgrade to 3/8ths polycarbonate. 1/4" probably deflects too much, even un-lightened.
It doesn't end up saving you weight over an optimized aluminum gearbox, but it's hard to do gearboxes with polycarbonate.
Unread 30-10-2015, 19:15
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Having built several polycarbonate gearboxes I would have to agree with this. If it were designed like an actual box, where you have polycarbonate connected on all 6 sides supporting itself you might be able to get away with 1/4" (as my team has in the past), but if you plan to support it like that, you'll definitely want to go to 3/8" for rigidity.
You might also consider mounting another plate of polycarbonate between the gearbox and the output sprocket. Having less distance between plates should improve the rigidity.
This is what we built a few years back. Note that the aluminum plate was eventually replaced with polycarbonate. Also worth noting that the gearbox is still around 8 years later. The gears failed a while back, but the box is still in great shape.
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Very nice, I've been researching good plastics for gearboxes and found that acetal and thick polycarb will work fine, but polycarb does have more flex in it. I'd recommend some sort of bracing/stand for the cims to hold them in place during load (as said above).
Also, 254 has made a plastic-based gearbox and made their mounting frames out of acetal.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 30-10-2015, 15:54
If you could do a stress test on the holes compared to the WCP gearbox plates, that would be interesting to see.
Unread 30-10-2015, 16:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It wasn't worth it though and I'm pretty sure the solid delrin plate was just about as heavy as a pocketed aluminum plate...and substantially less rigid.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-10-2015, 20:34
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
On top of that, I recall having issues with being unable to draw heat out of the CIM motors since we used delrin plate.
We did a test with the same gearbox under the same load using pocketed aluminum plate. It resulted in having a cooler motor over the same testing duration.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
