Go to Post It's a shame that this is likely the year that sacred ground will be touched by that unworthy drive :rolleyes: - AdamHeard [more]
Unread 30-10-2015, 12:16
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Re: pic: Poly-carbonate 2 Speed Gearbox
Very nice, I've been researching good plastics for gearboxes and found that acetal and thick polycarb will work fine, but polycarb does have more flex in it. I'd recommend some sort of bracing/stand for the cims to hold them in place during load (as said above).
Also, 254 has made a plastic-based gearbox and made their mounting frames out of acetal.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 30-10-2015, 15:54
If you could do a stress test on the holes compared to the WCP gearbox plates, that would be interesting to see.
Unread 30-10-2015, 16:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It wasn't worth it though and I'm pretty sure the solid delrin plate was just about as heavy as a pocketed aluminum plate...and substantially less rigid.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-10-2015, 20:34
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
On top of that, I recall having issues with being unable to draw heat out of the CIM motors since we used delrin plate.
We did a test with the same gearbox under the same load using pocketed aluminum plate. It resulted in having a cooler motor over the same testing duration.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
