Go to Post You won't find anything in school that says you have to share ideas or strategy with your football rivals. - Al Skierkiewicz [more]
Unread 30-10-2015, 16:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Poly-carbonate 2 Speed Gearbox
Originally Posted by jkelleyrtp View Post
Also, 254 has made a plastic-based gearbox and made their mounting frames out of acetal.
It wasn't worth it though and I'm pretty sure the solid delrin plate was just about as heavy as a pocketed aluminum plate...and substantially less rigid.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-10-2015, 20:34
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
On top of that, I recall having issues with being unable to draw heat out of the CIM motors since we used delrin plate.
We did a test with the same gearbox under the same load using pocketed aluminum plate. It resulted in having a cooler motor over the same testing duration.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
