Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 02-11-2015, 00:44
Knufire Knufire is offline
Re: pic: Inverted 3 CIM 2 speed gearbox with PTO
You might have some trouble shifting that PTO depending on what it's powering. We coupled a 1.5" or 2" bore (can't quite remember) to a ball shifting shaft on our winch in 2014 to engage/disengage a ratchet and it often had problems shifting as the cylinder induces a bending moment on the shifting rod. No idea if you'll see the same problems with the smaller cylinder, but making sure the coupler is as stiff as possible will help.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
