Go to Post When the going gets tough, the smart keep their GP. - Libby K [more]
Unread 03-11-2015, 22:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: Introduction to Basic Robotics Parts/Systems
Nice intro to the robot! - I did notice a few minor points you might want to rearrange:
  • On the PCM slide, it states that the PCM has an integrated pressure switch. The switch is external to the PCM. It would be more accurate to say that the PCM has an integrated compressor shutoff controlled by a pressure switch.
  • On the motor controller slide, it isn't clear that all three of the displayed controllers can be operated via PWM.
  • What do you mean by the statement that the Classmate PC is the newest component? We're still using the same one we got four years ago, though most of the control system has since been replaced.
  • On the last content slide, "Signal Flow", the signals do not go through the PDP, but directly through the PWM cable from the RoboRIO to the Jaguar. If you wanted to add the PDP, I would also add the battery and breaker, and include a "power flow" (perhaps with red arrows) that goes from the battery through the breaker to the PDP, to the Jaguar, at which point it runs "with the signal" through the path to the wheels.
